Hello together,
I am using the 3D mesh for the first time and have some questions how to do it corretly.
Basicly I have 2 components which origin is an imported *.iges geometry. The first picture shows the component with a special shaped hole.
The second shows the part which shell be integrated in that hole
and the third shows the combined components.
so far I uses tetra mesh for each component individually. As you can see in the third picture there are some areas which overlap.
1. What can I do against those overlapping areas?
2. In general I want to have some areas of two components which are connected an some which move freely. How do I manage that?
Hope you can help me.
