Altair RISE
Nominate Yourself Now!
Problem by meshing Knee Modell Stl File by with SimLab
User: "Robin Müller"
New Altair Community Member
Updated by Robin Müller
Hello everyone.
I got a problem with meshing a Knee Modell stl file.
Surface Mesh is running, but when i do tetramesh it get an error: Body 1 has overlapp edges.
I follow instructions like here: https://community.altair.com/community?id=community_question&sys_id=98a6c47a1b2bd0908017dc61ec4bcb3c
but it doesn't work.
Have anyone of you an idea, what is to do? I also work with a Meshmixer tool to make the surface smoother, but it produce the same error.
Best regards,
Robin
1 - 4 of 41
    User: "AlessioLibrandi"
    Altair Employee
    Updated by AlessioLibrandi
    Please use the mesh check INTERSECTION to find the errors in the mesh
    They are just 3 or 4 problems. Like this one:
    I suggest then just to delete the error elements. Select and delete.
    Then, detect the holes (created by the deleting) with Free edges tool:
    And fill them up, for example using Create Element Option:  image
    Once Edge- and intersection Check gives no error you will be able to do your tet mesh. I did it for one of your examples: tetmesh is attached (as GDA to be imported into SL).
    Thanks, Alessio Librandi - SimLab Global Tech Team
    OP
    Hi Alessio,
    thank you so much for your support.
    I follow your instruction step by step for the trab file and find the errors with intersection and delete them. But the problem is that i cant find any edges after that, and the mesh will not be runnin. I cant see the elems inside the structure, so i cant create new one.
    Do you have any idea of my problem?
    Thank you so much.
    Best regards,
    Robin
    OP
    Now it works. I have reinstalled SimLab and it looks like it works. Thank you so much.
    OP
    Hi.
    I got one more question. There is a problem when i want to get the results it gives me a fail message.
    Do anyone know what i do wrong?
    Best,
    Robin
