🎉Community Raffle - Win $25
Join and Win
No results after Optistruct and Multiscale co-simulation
SevilUser: "Sevil"
Altair Community Member
Updated by Sevil
Hello all,
I'm new user in Multiscale designer.My aim is to create material model in Multiscale designer and of course for fiber orientation data I used Inspire mold(I have no problem about that)But in Hyperworks interface,I prepared my model for nonlinear analysis with multiscale material model and when I started solution ,as you see I got this message " job  completed" without results and  with any errors.What is the problem?
In addition my run directory is:
Please help me for the issue. Thanks in advance.
1 - 5 of 51
    Hi,
    can you sahre the .out file of OptiStruct?
    Is there anything unusual there?
    What version are you using, and what kind of license do you have?
    SevilUser: "Sevil"
    OP
    Updated by Sevil
    Hi,
    Hello Adriano,
    Thank you for the feedback ,in attached file I share and also I use 2021 student version.
    SevilUser: "Sevil"
    OP
    Updated by Sevil
    Hi,
    In addition There is no unusual situation.If you want,I can share fem file.
    Rahul_P1User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    HI, Can you confirm you have the installation directory set in the settings (gear symbol)
    SevilUser: "Sevil"
    OP
    Updated by Sevil
    Hello Mr.Ponginan,I hope you're well.As you see below,same your inst. directory.I have limited time and really need help about this.
