warning quality mesh
Hello every one
when I run the OptiStruct in the .out file i found these warnings . can i cancel this option under OptiStruct ?
Element # 6, element type TETRA.
WARNING - Outside of recommended range: Face Skew Angle = 76.060
upper limit = 75.000
WARNING - Outside of recommended range: Face Vertex Angle = 7.4711
lower limit = 15.000
WARNING - Outside of recommended range: Edge Angle = 81.129
1 - 6 of
61
to bypass element quality checks (except essential validity checks) , use PARAM,CHECKEL,NO
This is created in the control cards panel,
It is advised however that you improve the quality of your mesh, see element quality checks and fixing tips in the student guide and the training center here- http://training.alta...lement-quality/
