Material Property Optimization
Hello,
I'm starting to work with optistruct and would like to include the optimization of the stiffness modulus (E modulus) in my model. Running an optimization where the material orientation of a composite structure is specified as a design variable (DESVAR) is straight forward, but is it also possible to specify a design variable for the E1 and E2 values when trying to maximize the normal modes of a structure?
kind regards,
Mark
