Jump in Total Energy
Hello together,
At the moment I am working on impact simulations in Radioss. I have an aluminium cylinder (solid elements, MAT Law 2, Initial Velocity) impacting a rigid wall. The total energy (TE = KE + IE) should be constant, but there is a jump in the curve. The DTE curve remains constant. The external work shows a decrease, too. Is my simulation correct? Should i use the DTE curve instead of the TE curve for validation?
Hi,
Can you plot IE and Hour glass energy?
Taking into account the external works, the total energy must remain constant or decrease slightly. The total energy can increase at the end of the computation, during the spring back or at the beginning during the first cycles.
Internal energy + Kinematic energy + Hourglass energy + Contact Energy + … = Variation of the External Work
If under-integrated elements are used, the total hourglass energy must remain lower than 10% of the total energy. If this is not the case, the mesh should be reworked or elements with physical stabilization method should be used.
So the simulation results are correct?
I made another simulation yesterday. This was a simulation of a sphere impacting a rigid wall. The sphere had the same property, material and initial velocity as the aluminium cylinder above. There was no slight decrease in the total energy. Due to this i am not shure about the above decrease
Hi,
how's about hourglass?
where are KE & IE curves?
