🎉Community Raffle - Win $25
Join and Win
ENERGY ERROR LIMIT REACHED
User: "Amasker"
Altair Community Member
Updated by Amasker
Hi,Recently encountered this problem
*** ERROR # 4002 ***
 Running RADIOSS engine, 2 ERRORs and 0 WARNINGs have been detected.
 They are listed below.
 ENGINE ERROR:
  ** RUN KILLED : ENERGY ERROR LIMIT REACHED
 ENGINE ERROR:
Then I checked the .0001 file,find the following error:
***  PARTS WITH HIGHEST KINETIC ENERGY
      PART_ID   K-ENERGY   PROP_ID PROP_TYPE    MAT_ID  MAT_TYPE
         8 0.9779E+42         8        11         3        25
         5 0.2085E+17         5         1         2         2
         4  5274.             4         1         2         2
 ***  PARTS WITH HIGHEST INTERNAL ENERGY
      PART_ID   I-ENERGY   PROP_ID PROP_TYPE    MAT_ID  MAT_TYPE
         2 0.1588E+44         2         1         2         2
         8 0.3382E+34         8        11         3        25
         3 0.2991E+26         3         1         2         2
         6 0.3831E+15         6         1         2         2
         5 0.6502E+09         5         1         2         2
         4 0.1186E+08         4         1         2         2
***  NODES WITH HIGHEST VELOCITY
      NODE   VELOCITY     K-ENER       MASS      MASS0   DM/MASS0
   2115893 0.4969E+20 0.8813E+31 0.7140E-08 0.1963E-08  2.637
   2115885 0.1871E+20 0.3213E+31 0.1836E-07 0.3914E-08  3.692
   2115894 0.1445E+20 0.8372E+30 0.8017E-08 0.1981E-08  3.047
   2021296 0.8145E+19  0.000      0.000     0.2616E-08 -1.000
   2021295 0.6374E+19  0.000      0.000     0.4702E-08 -1.000
   2115886 0.5165E+19 0.2000E+30 0.1499E-07 0.3825E-08  2.920
   2813216 0.4677E+19  0.000      0.000     0.2000E-08 -1.000
   2813011 0.4677E+19  0.000      0.000     0.3984E-08 -1.000
   2813103 0.4676E+19  0.000      0.000     0.8164E-09 -1.000
   2021031 0.3395E+19  0.000      0.000     0.2111E-08 -1.000
I can't figure out the reason about it,element?velocity?mass? I don't know,
The   workd ,The outer plate is a steel plate and the inner plate is a composite material.
But in  ,I just make some changes,offset some element for composite,then,the error occurs。
Can someone help me check the reason of the error?
