🎉Community Raffle - Win $25
Join and Win
ENERGY ERROR LIMIT REACHED
User: "Amasker"
Altair Community Member
Updated by Amasker
Hi,Recently encountered this problem
*** ERROR # 4002 ***
 Running RADIOSS engine, 2 ERRORs and 0 WARNINGs have been detected.
 They are listed below.
 ENGINE ERROR:
  ** RUN KILLED : ENERGY ERROR LIMIT REACHED
 ENGINE ERROR:
Then I checked the .0001 file,find the following error:
***  PARTS WITH HIGHEST KINETIC ENERGY
      PART_ID   K-ENERGY   PROP_ID PROP_TYPE    MAT_ID  MAT_TYPE
         8 0.9779E+42         8        11         3        25
         5 0.2085E+17         5         1         2         2
         4  5274.             4         1         2         2
 ***  PARTS WITH HIGHEST INTERNAL ENERGY
      PART_ID   I-ENERGY   PROP_ID PROP_TYPE    MAT_ID  MAT_TYPE
         2 0.1588E+44         2         1         2         2
         8 0.3382E+34         8        11         3        25
         3 0.2991E+26         3         1         2         2
         6 0.3831E+15         6         1         2         2
         5 0.6502E+09         5         1         2         2
         4 0.1186E+08         4         1         2         2
***  NODES WITH HIGHEST VELOCITY
      NODE   VELOCITY     K-ENER       MASS      MASS0   DM/MASS0
   2115893 0.4969E+20 0.8813E+31 0.7140E-08 0.1963E-08  2.637
   2115885 0.1871E+20 0.3213E+31 0.1836E-07 0.3914E-08  3.692
   2115894 0.1445E+20 0.8372E+30 0.8017E-08 0.1981E-08  3.047
   2021296 0.8145E+19  0.000      0.000     0.2616E-08 -1.000
   2021295 0.6374E+19  0.000      0.000     0.4702E-08 -1.000
   2115886 0.5165E+19 0.2000E+30 0.1499E-07 0.3825E-08  2.920
   2813216 0.4677E+19  0.000      0.000     0.2000E-08 -1.000
   2813011 0.4677E+19  0.000      0.000     0.3984E-08 -1.000
   2813103 0.4676E+19  0.000      0.000     0.8164E-09 -1.000
   2021031 0.3395E+19  0.000      0.000     0.2111E-08 -1.000
I can't figure out the reason about it,element?velocity?mass? I don't know,
The   workd ,The outer plate is a steel plate and the inner plate is a composite material.
But in  ,I just make some changes,offset some element for composite,then,the error occurs。
Can someone help me check the reason of the error?
1 - 8 of 81
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Are these elements part of contact?
    User: "Amasker"
    OP
    Updated by Amasker
    @Prakash Pagadala
    I don't know what do you mean?I'm confused abou the contact between the rigid wall and the B-pillar?
    In addition, there is a downward slide after the collision, how to prevent this from happening
    Altair Employee
    @Prakash Pagadala
    I mean the elements which were offset from their original position, are they part of the contact interface?
    To avoid sliding, constraint the rigid tube.
    User: "Amasker"
    OP
    Updated by Amasker
    Prakash Pagadala
    The offset element Tie with  the original element, but is not in contact with the rigid wall,
    and how to restrain the rigid wall from slipping?
    Please check the .fem file,thank you。
    Altair Employee
    Prakash Pagadala
    OK, I thought it is a tube which is made rigid. I will check and update you soon.
    User: "Amasker"
    OP
    Updated by Amasker
    Thank you,could you provide the method about how to constraint the rigid tube?
    User: "Amasker"
    OP
    Updated by Amasker
    @Prakash Pagadala
    In the.0001 file ,the error messages details shows following,
    ERROR : NEGATIVE STIFFNESS NODE
    Could you give me some advice ? How to solve this kind of question?thank you
    Altair Employee
    The error could be due to contacts or due to material properties. If you have unrealsitic material properties, such error pops up.
    Please check the contacts, material properties and units.
