Altair RISE
Nominate Yourself Now!
Querying about some element for 1D- stress value
User: "Vikas Kumar_22189"
Altair Community Member
Updated by Vikas Kumar_22189
Dear all,
I wants to perform query for some element not for whole model as shown in below picture.
I am trying with this code but in this it is giving miximum value only for whole model but i want result for specific element ID. can anyone help me.
My code is.
                                     Model handle i got earlier as mh$t .
                                    mh$t GetQueryCtrlHandle qch$t
                                    qch$t SetDataSourceProperty result datatype Stress
                                    set set_query 'contour top 1'
                                    set set_result_component 'contour.value'
                                    set id_SelectedNode [mh$t AddSelectionSet element]
                                    mh$t GetSelectionSetHandle selection_set_handle_node$t $id_SelectedNode
                                    # selection_set_handle_node$t Add $set_query
                                    selection_set_handle_node$t Add $SpecificElem_ID ; # adding specific element which was added b4
                                    qch$t SetSelectionSet $id_SelectedNode
                                    qch$t SetQuery 'contour.value'
                                    qch$t GetIteratorHandle i$t
                                    i$t First
                                    if { [i$t Valid] } {
                                        set contourValue [i$t GetDataList]
                                        puts 'contourValue: $contourValue'
                                    } else {
                                        set contourValue 'N/A'
Thanks,
Vikas Kumar
1 - 5 of 51
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Vikas,
    You can pass the element Ids you want to the below procedure:
    proc contourValue {lst_elements} {
        hwi OpenStack
            set t [clock clicks]
            hwi GetSessionHandle session$t
            session$t GetProjectHandle project$t
            project$t GetPageHandle page$t 1
            page$t GetWindowHandle win$t 1
            win$t GetClientHandle anim$t
            anim$t GetModelHandle my_model$t [anim GetActiveModel]
            my_model$t GetQueryCtrlHandle my_query$t
            set set_id [my_model$t AddSelectionSet element]
            my_model$t GetSelectionSetHandle elem_set$t $set_id
            foreach id $lst_elements {
                elem_set$t Add 'id $id'
            my_query$t SetSelectionSet $set_id
            # my_query$t SetQuery 'element.id contour.value';
            my_query$t SetQuery 'contour.value'; #only contour value
            my_query$t GetIteratorHandle my_iter$t
            set data_list ''
            for {my_iter$t First} {[my_iter$t Valid]} {my_iter$t Next} {
            lappend data_list [my_iter$t GetDataList]
            puts '$data_list----data_list';
            my_model RemoveSelectionSet $set_id
        hwi CloseStack
    Regards
    llyle
    OP
    Hi Livil,
    It is Giving contour value for only one element.
    But in selection set all element id is present.
    Regards,
    Vikas
    User: "llyle_20499"
    You'll have to add element by element.
    User: "Mahesh Agrani"
    Updated by Mahesh Agrani
    Thanks for sharing @Livil Lyle, where to add element ids eg. 700001, 700002, 700003 etc?
    User: "llyle_20499"
    source the proc contourValue above,
    set lst_elems  {700001 700002 700003}
    contourValue $lst_elems
    I would recommend you to get more familiar with tcl programming before getting into HV automation.
