Mesh transition coarse to finer - Easy way to create nodal ties?
Wesley_Peijnenburg2
Wesley_Peijnenburg2 Altair Community Member
edited October 2023 in Community Q&A
A simple mesh is created with coarse and fine elements:
There are two nodes indicated in red which are not properly connected, as is clearly visible in the displacement results below:
Aside from using a triangle/trapezoid transition mesh, a nodal tie can also solve this problem? In this case, the displacement of the red node would need to be tied to the corners of the adjacent bigger element.
My question:
Is there an easy way to make such nodal ties (or maybe alternative way to solve this problem)? Especially for larger meshes an automatic method would be needed (assuming floating nodes are always centered on the edge of a larger element)?
The model is attached.
Welcome!
Best Answer
Answers
Welcome!
Welcome!
