🎉Community Raffle - Win $25
Join and Win
Choosing the right element as torque input
User: "reza hakimi_20486"
Altair Community Member
Updated by reza hakimi_20486
Hello
In this circuit, I intend to rotate the bldc generator shaft with the desired values
For this purpose, I used the element in the picture, which is a load with an external controller.
The torque on the shaft reaches the desired values, but the speed of the shaft becomes extremely unstable and fluctuating. What is the solution to this problem or what other element can I use?
Thanks
