🎉Community Raffle - Win $25
Join and Win
Simlab and Topology Optimization
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
three questions about the topology optimization with simlab:
1) does simlab support postprocessing topology optimization results?
2) I cant find any manufacturing constraints, like mindim in simlab? are they not available?
3) I set up a topology optimization in simlab. it works fine but i cant start the optimization directly from simlab. why the function is not activated? (see pic)
Thank you
1 - 7 of 71
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Yes Simlab support post processing of Topology Optimization results.By the way which version of Hyperworks simlab you are using?
    Also Hyperview is the recommended tool for post processing.
    See atthached screenshot for mindim.
    By default it should take Optistruct solver for analysis & optimization.If possible please share simlab .bat file.
    Altair Employee
    OP
    Rahul,
    thank you for you replay. I still have a problem with the import. Can you tell me how to import the optimization results in simlab. Is it possible to set the density ISO in simlab?
    This is the simlab.bat:
    @ECHO OFF
    REM ************************
    REM SimLab License file
    REM set ALTAIR_LICENSE_PATH=
    set CAE_HOME=%~pd0
    call '%CAE_HOME%\vp_init.bat'
    start '' /B %SL_START_CMD% %SL_START_CMD_ARG% %*
    Requesting you to share Vp_init.bat file.
    C:\Program Files\Altair\14.0\SimLab14.3\bin\win64
    Altair Employee
    OP
    Rahul,
    Vp_init.bat as requested:
    @ECHO OFF
    if defined STS_INIT_DONE goto :EOF
    set STS_INIT_DONE=TRUE
    REM CAE - Application
    if not defined CAE_HOME set CAE_HOME=%~pd0
    set PATH=%CAE_HOME%;%PATH%
    REM Unity Variables
    set HW_PLATFORM=win64
    set ALTAIR_HOME=%CAE_HOME:~0,-10%
    set HW_ROOTDIR=%ALTAIR_HOME%
    set HW_UNITY_ROOTDIR=%HW_ROOTDIR%\unity
    set PATH=%PATH%;%HW_UNITY_ROOTDIR%\bin\%HW_PLATFORM%;
    REM ***************************
    REM SimLab specific parameters
    set VP_SCRATCH_DIR=%TEMP%\SimLab\SimLab 14.0 64-Bit\Temp
    if not exist '%VP_SCRATCH_DIR%' mkdir '%VP_SCRATCH_DIR%'
    REM ******************************
    REM SimLab Project File Directory
    set STS_PROJECT_LOC=%TEMP%\SimLab\SimLab 14.0 64-Bit\ProjectDir
    if not exist '%STS_PROJECT_LOC%' mkdir '%STS_PROJECT_LOC%'
    REM SimLab License Path
    if not defined ALTAIR_LICENSE_PATH set ALTAIR_LICENSE_PATH=%CAE_HOME:~0,-23%\security\altair_lic.dat
    REM Parasolid Import
    set PATH=%CAE_HOME%\parasolid;%PATH%
    set P_SCHEMA=%CAE_HOME%\parasolid/Schema
    REM *************
    REM Step Import
    REM *************
    set PATH=%CAE_HOME%\step;%PATH%
    REM ***************
    REM CAD Translator
    REM ***************
    set PATH=%CAE_HOME%\sl_cad_translator;%PATH%
    REM ProE Install Path
    SET VP_PROE_HOME_DIR=%CAE_HOME%\proe\wildfire3.0
    set VP_PROE_CMD_DIR=
    set VP_PROE_CMD=
    set PATH=%VP_PROE_CMD_DIR%;%VP_PROE_HOME_DIR%;%PATH%
    set VP_PRO_PAUSE=0
    REM Catia Install Path
    set SL_CATIA_INSTALL_DIR=
    set PATH=%SL_CATIA_INSTALL_DIR%\win_b64\code\bin;%SL_CATIA_INSTALL_DIR%\win_b64\code\command;%PATH%
    REM CATIA Step Approach
    set CATIA_SCRATCH_DIR=%CAE_HOME%\Temp\Catia
    set CATIA_CMD=catia.bat
    set PATH=%CATIA_SCRATCH_DIR%;%PATH%
    REM CATIA Direct Access
    set SL_CADNEXUS_DIR=%CAE_HOME%\cadnexus\CAPRI
    set CATEnvCAPRI=
    set PATH=%CAE_HOME%\cadnexus\3.20;%SL_CADNEXUS_DIR%\lib;%PATH%
    REM CATIA Variables for SimLab
    set IMPORT_CATIA_PUBLICATIONS=TRUE
    set SIMLAB_READ_CATIA_PART_NUMBER=FALSE
    set SIMLAB_RESET_CATIA_FACE_COLOR=FALSE
    REM ************
    REM UG Import
    REM ************
    set SL_UG_INSTALL_DIR=
    set PATH=%SL_UG_INSTALL_DIR%;%PATH%
    REM JT Import Parasolid
    set PATH=%CAE_HOME%\jtopen;%PATH%
    REM Parasolid Translator
    set PATH=%CAE_HOME%\parasolidtranslator;%PATH%
    REM ***********************************
    REM UG Attribute ug-open=1 cadnexus=2
    set SL_ATTRIBUTE_READ=0
    REM H3D Reader
    set PATH=%PATH%;%CAE_HOME%\HW_HM\HW-13.0.110\io\result_readers\bin\win64
    REM Clean up Older Version Help Docs
    if exist  '%LOCALAPPDATA%\Trolltech' rmdir/s /q '%LOCALAPPDATA%\Trolltech'
    REM It Creates element fast
    SET STS_FAST_CREATE_ELEM=TRUE
    REM SimLab UI Related Variables
    set UNITY_SL_PROJECT=1
    set SHOWORHIDE_DESELECT=0
    set UPDATEGRAPHICS_FLAGBASED=1
    set SL_DIALOG_VALUES_PRESERVE=true
    set UNITY_SELECTION=1
    set BROWSER_BLUE_TEXT=1
    set UNITY_DIALOG_ANIMATION=0
    set SL_SAVE_SESSIONFILE_IN_DISC=true
    if not defined SL_ENABLE_SCRIPT SET SL_ENABLE_SCRIPT=1
    REM set SL_EXPORT_ABAQUS_QUALITY_FAILED_ELEMENTS=TRUE
    REM set SL_FLUENT_INTERFACE_GROUP_METHOD=TRUE
    set SESSION_TESTING_COMPARE=false
    REM set STS_N_KGF_UNIT_CONVERT=FALSE
    set SKIPUPDATES_CALLBACK=TRUE
    set ENTITYDISPLAY_IN_LINEEDIT=20
    set SL_SHOW_AUTOMATION_SESSION=false
    SET SL_START_CMD='%HW_UNITY_ROOTDIR%\bin\%HW_PLATFORM%\hwx.exe'
    SET SL_START_CMD_ARG=-sf plugins\simlab\resources\exec_icons\splash.jpg -v SimLab_V14.0 -client simlab
    CALL '%CAE_HOME%\STS_solver_setup.bat'
    Altair Employee
    OP
    Rahul,
    a additional question. You said Simlab supports post processing of Topology Optimization results.
    I try this but with no success. I have set up a topology optimization in SimLab, afterwards I export it and start optistruct. Then i tried to import the h3d_des result in Simlab.
    Simlab shows the model, but no results. where is the bug?
    Thank you
    If possible could you please switch to latest vesrion Simlab 14.3. or
    The STS_solver_setup.bat contains the solver path to solve while solving.
    If this is defined then optimize should be enabled
    Did you try loading h3d file in Hyperview.HV is the recommended tool for post processing.
