Altair RISE
Nominate Yourself Now!
Is it possible to plot the reverse of the composite failure index in Hyperview?
User: "Casper Kruger"
Altair Community Member
Updated by Casper Kruger
Hi,
I am doing a benchmark simulation and require the reverse factor of the composite failure index. Is this output available in Hyperview or does it need to e calculated separately?
Kind regards,
Casper Kruger
1 - 6 of 61
    User: "Adriano Koga_20259"
    New Altair Community Member
    Updated by Adriano Koga_20259
    Are you looking for Strength Ratio?
    The Strength Ratios that are output as a result of PARAMSRCOMPSYES depend on the Failure Theory specified by the user. The following equations show the relationship between the Failure Index and the Strength Ratio for different Failure Theories.
    Hill Failure Theory:
    StrengthRatio=1FailureIndexStrength Ratio=1Failure Index
    Hoffman Failure Theory: There is no direct relationship between the Strength Ratio and Failure Index (refer to Composite Laminates in the User Guide for more information). OptiStruct solves the quadratic equation to find the strength ratio.
    Tsai-Wu Failure Theory: There is no direct relationship between the Strength Ratio and Failure Index. (refer to Composite Laminates in the User Guide for more information). OptiStruct solves the quadratic equation to find the strength ratio.
    Maximum Stress (Strain) Failure Theory:
    Transverse Shear Failure Theory:
    If that's not exactly what your looking for, you can always create your own result from the Failure Index, by using Result Math,similarly to this thread here:
    https://community.altair.com/community?id=community_question&sys_id=b3c8fb0fdb20a490e8863978f49619ad
    OP
    Adriano
    Thank you for the reply as well as the additional link, that will do the trick. Is there a way to run all the failure theories in one run and export the results to a table to compare?
    Adriano
    PARAM,ALLFT,YES or something like that. Not sure if this covers SR.
    User: "Michele Macchioni"
    Altair Employee
    Updated by Michele Macchioni
    Casper,
    you may want to check several failures as well outputting op2 results from OS and then use HV composite modules to run post cross evaluation.
    We developed (motivated by Airbus request) an extra tool called "Composite Failure Wizards" which you can access from the Aerospace menu (OS profile) in HyperMesh.
    You can use it to as well set the material allowables associated to the MAT8 cards.
    The tool writes an XML statement which triggers then HV to process the data automatically without you having to input the expression in derived results.
    I have attached a quick video for the same.
    Extra tip: if you run HVTRANS on that XML you get as well the h3d version of it.
    Hope this can help you further.
    Regards
    Michele
    OP
    Michelle,
    Thank you for the video, it does help thank you. Just so the thread is complete, I received the below method from customer support as well:
    1. You can export a set of results by using the aerospace tools in Hypermesh.
    2. If you import your model in HM and change the user profile to Engineering solution -> aerospace, aerospace tool will become available
    3. From there click on File Loader to load the results file and import it.
    4. Then click on results query
    5. And select the results you want to save in a csv file
     or
    1. Try with the build plot tool in HV to reduce the number of clicks.
    2. Here you can select your set of results (stress, strain, failure index) and plot all the relative results in a graph.
    3. If you click on the plot, the export curve button will become available and you can export all the data to a csv file
    Thank you,
    Casper Kruger
    Altair Employee
    Michelle,
     or
    Thank you,
    Casper Kruger
    Hi Casper,
    the above workflow support provided to you are correct when it comes to output multiple available data into a CSV and they work pretty slick.
    I am personally bound to the Results Query tools as I had been overseeing its development :)
    That being said, the workflow I passed you is indeed aimed to:
    - create new results (several composite failures in one shot)
    - control/change (if required) material allowables (so you can trade-off several variants)
    Surely, once the h3d is for instance available you use any of the mentioned tools to export such data.
    More is as well to come as we are working to directly connect Matrix Browser with results entities in NGHW.
    Thanks and regards
    Michele
