Hi
I try to subtract 2 objects as show in picture. However 2 object disappeared. Please view attached files for more details.
Best regards
Travis
Hello,
The body is not a closed solid.
You can check this using Analysis-> Tolerance Check (see picture).
If you correct that, it works.
Best Regards,
Mario
