Thermal Flow Equation in AcuSolve
Vignesh  Lakshmanan
Vignesh Lakshmanan Altair Community Member
edited July 2021 in Community Q&A
Hello,
I would like to understand what is thermal flow ( in solver controls - active equations, if we enable heat transfer) and when should we enable it.
Thanks
Best Answer
  • Junta_20361
    Junta_20361 New Altair Community Member
    edited July 2021 Answer ✓
    hi,
    Please refer to acusolve tutorial AcuT3000: enclosed hot cylinder.
    In this tutorial, they have explain the meaning of "thermal flow" in the solver control:
    The choice generally depends on the degree of coupling, that is, buoyancy, between the momentum and thermal equations; forced convection problems may be solved staggered, while free convection problems usually benefit from the more expensive coupled approach (from acusolve help)
    In short, this option is needed when you solve the natural convection problem.
Answers
  • Junta_20361
    hi,
Welcome!
Welcome!
