Unresolved problem with the resultant vector of pressure
Hello,
I'm had this problem for a while now and still cannot find a solution... namely a problem with changing the direction of pressure from normal to OZ axis. The program seems to be completely unresponsive to my commands. Below I am posting a short video of the issue. In the end the calculated resultant force should only have one non-zero component (Z). I would be very grateful for your help. Thank youhttps://www.youtube.com/watch?v=DiOm7d-oQuI
For that HM, with no modifications at all, Loads Summary shows me no forces except global Y in that model (it is identical to my own test model pretty much!), this in 2021.2.
Interesting. I'm also working on the same 2021 patch. The only difference being it's a student's version. What's even more troubling is that I'm having the exact same bug on both of my computers. I'll try contacting Altair support. Thank you for your answers!
Maybe worth trying deleting all your settings files, see 'most viewed posts' on right, sometimes a config or preferences file can get messed up, if that is what you see when you export a fem though, it suggests, either your HM is exporting it or displaying the data correctly, the attached fem was written from your HM in my session, and on import shows correctly, what do you get from this?
I followed the instructions on "how to delete settings files" and deleted all files mentioned except for hmsettings.tcl for it was absent in the directory folder. I'm working on default HM, maybe that is why.
As for the FEMs.. I opened both of our export files side by side and compared the two. They are exactly the same.
ok, that suggests a display issue then, since we know the fem I wrote out has the pload4 defined in Y
Not sure what else the issue could be here, is your graphics card patched up to date?, 2021.2 needs at least 451.77 if you are on an nvidia card or 20.Q3 on an AMD, might sound odd, but graphics drivers can cause issues with loads display
