🎉Community Raffle - Win $25
Join and Win
Variations with RD-3500: Tensile Test
Hello Sirs,
I want to test my composite material dogbones at different temperature and velocity conditions. I used RADIOSS ''RD-3500: Tensile Test'' tutorial as a base to setup my Boundry conditions.Please suggest how can i apply different velocity and temperature conditions.
Am i right if i give 'velocity value for ex. Vx=3' in Property section (in browser area)
 & Temperature T0=50°C(323 kelvin ) in Material section (of browser area)
I have added the material vales ( like E,mu & rho) and integration points, N=5, and used MAT1 card (considering material behaves Isotropic) for initial test calculations.
The error i got is attached. I am also attaching my model, if it helps.
Secondly,
When i run the RD-3500: Tensile Test, i observed that ''the final animation result doesnot show any change in thickness at the centre and final breakage after elongation''. Can you suggest, how can i create a more realistic animation ?
Also, i am interested in generating a few plots like :
.) Velocity-Elongation
.) Velocity-Emodul
.) Velocity-tensile strength
and also, influence of temperature on all the above parameters.
So please suggest what control cards should i use and how can i view these plots in Hyperview/Hypergraph.
Your suggestions would really help me with my Master thesis.
i will really appreciate your feedback on my query.
Mit freundlichen Grüßen/Best Regards,
i.A. Palash Agrawal
MSc. Computational Mechanics
Universität Duisburg Essen
ES0301042200
Tel.: +49 176 4160 9591
<?xml version="1.0" encoding="UTF-8"?>post-36170-0-64517400-1432654174_thumb.j
1 - 9 of 91
