🎉Community Raffle - Win $25
Join and Win
Buckling Analysis Composites (PCOMPP)
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear,
I am trying to preform a buckling analysis of a composite sandwich material.
But the Auto-SPC limits the DOF's of the composite skins, so that buckling can not happen in correct way.
When the Auto-SPC is dissabled, the solver gives the error which states that the DOF's of these elements should be limited, because they have no stiffness in that direction.
This is true, due to the material and property assignment (Mat 8, and PCOMPP) which does not provide stiffness in the 3th direction.
Is there a work around?
I also did a dynamic test (Radioss) where the specimen does not buckle according to the first mode.
Test to be replicated:
<?xml version="1.0" encoding="UTF-8"?>To_Be_Replicated.thumb.jpg.e0ae66a9c17f43d520f61d593ff50ec1.jpg
Optistruct First mode
Faulty result due to Auto SPC
RADIOSS Result
1 - 9 of 91
    Altair Employee
    OP
    Hi,
    Can you model the layers with solid elements and use MAT9ORT?
    You can use PCOMPLS you model solid layers.
    Altair Employee
    OP
    Hi,
    I can do this, but up until now I have refrained from using 3D elements for the modelling of the composite skins because of the error introduced when modelling slender elements using solid elements.
    Like is mentioned in the Altair Book 'Practical Aspects of Finite Element Simulation', and in University.
    Would this be a large error?
    I will try the 3d element method, and report back in a few hours
    Altair Employee
    OP
    HI,
    I never assessed the error margin for an orthotropic material model.
    If you see anything strange, please let us know.
    Altair Employee
    OP
    PCOMPLS is not supported in Buckling analysis
    I will try something different using 3D elements
    *** ERROR # 4233 ***
     Layered solid shell composites (PCOMPLS) is not supported
     in buckling analysis.
    (There are some other warnings and stuff, but I haven't debugged properly, because using this property will not work for the analysis.)
    Altair Employee
    OP
    Hi @ArneDerluyn
    Can you try with PSOLID.  I think that is the only way to provide stiffness in the thickness direction.
    Altair Employee
    OP
    Okey,
    I now have a working model.
    But the Modal analysis creates a self-intersecting geometry, which indicates that something is still wrong.
    I have assigned different PSOLID properties per ply, by transforming the stiffnesses according to the fibre direction.
    This is something which I generally try to avoid because it is a seed for errors.
    The model also shows some edge effects.
    This model is less strong than the physical test, the model indicates only 72% of force allowed versus the physical test.
    Buckling result (Mag x10)
    Altair Employee
    OP
    Hi @ArneDerluyn
    I will check and update you soon.
    Altair Employee
    OP
    how to create a metal and carbon plies in single laminate
    Altair Employee
    OP
    Hi,
    You can use MAT1 card for modeling metal and use the same in your laminate.
