Altair RISE
Nominate Yourself Now!
The group specified does not exist in the database [error]
User: "Anna_22598"
Altair Community Member
Updated by Anna_22598
Hello there!
When I try to follow the instruction I get stuck at step 5.
When I try to select the nodes I get this message "The group specified does not exist in the database.":
Where should I look for the error?
___
Additional info:
Tutorial: https://2021.help.altair.com/2021/hwsolvers/os/topics/solvers/os/extended_surface_heat_transfer_fin_r.htm#extended_surface_heat_transfer_fin_r
1 - 3 of 31
    User: "PaulAltair"
    Altair Employee
    Updated by PaulAltair
    It looks like you are trying to 'add' to an existing interface (that doesn't exist yet), rather than creating a new one? (change to the 'create' button instead of add), I just went through the steps as written in the tutorial and had no issue with this step in v2022. Also. From your screenshot I can see you are using HM 12.0? This type of analysis wasn't supported until later releases of v12 I don't think, so you may run into issues later anyway? (this is all from a very long time ago so I may be misremembering) note in tutorial says:
    I would really recommend updating to a newer version, since v12 is now 8 releases ago!
    User: "PaulAltair"
    Altair Employee
    completed files, if it helps
    User: "Anna_22598"
    OP
    Thanks for your comment. I have already solved the problem, I actually did it in the wrong order. Unfortunately, I can't update the program as this is the only version available at my work. :) I have the latest version privately and there I have no problems. Thank you!
