Rigid Spider around holes
Hi All,
Is there any way to make ridig spider around holes more than one in same time? I have a part with many holes so its taking so much time making rigid spider around them one by one.
I found there is kind of macro in Nastran solver utility section but its not working well.
If you have any solve please support me thank you.
Altug Bey,
It is an "Attachment" I have attached the help link below which explains this. For more detailed information, You can check the "connector" section in help.
You can do this with 'attachments' between parts using connector control manager (must be HM parts, if you only have 'components', create parts and move comps into them, or if you have multiple components, create a part assembly and create parts from that)
