🎉Community Raffle - Win $25
Join and Win
Question about custom property in the simulation with parallel cpus
User: "Raheem Sterling_22160"
Altair Community Member
Updated by Raheem Sterling_22160
Hi
I have added a custom properties for each contact to store some value, for example myvalue[n].
If I retrive this value like "double tmp = myvalue[0]", where "tmp" was defined in the calculateforce(), then all the calculation I used tmp, in the parallel mode, does "tmp" for each contact  assgined correctly?
Thanks
1 - 4 of 41
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi Raheem,
    Yes...and no.  It will depend on how you are using tmp.   It will assign myvalue[0] to tmp when called, and do this for every contact every time-step, and also be doing this simultaneously per thread.
    If you are setting tmp from 'contact 1' and then want to use this as a constant for contacts 1-n you would have to add some special condition, like only assigning if element1 and element2 ID's are specific values.  Also would want to apply it at t+1.  This is because  "double tmp = myvalue[0]" would set a new value per thread and also the contacts 1-n would come in a random order.
    However if you want to use  "double tmp = myvalue[0]" and have a unique value per contact then it would be OK.
    Regards
    Stephen
    OP
    Hi Raheem,
    Regards
    Stephen
    Thanks Stephen,
    For example of my code, rij_0 for each bond created at requested time, the force calculation of each bond depends on rij_0, and I used rij_0 and a_par in the calculation, from the results of simulations, it seems right at now. But I am not sure if I am using custom properties correctly.
    CSimple3DVector rij_0; RIJ = element2.position-element1.position; if(timeStepData.time >= m_requestedBondTime  && m_BondStatus[0] == 0.0 && nBondSeperation < 0.0)         {             m_InitialVectorIDelta[0] = RIJ.getX();              m_InitialVectorIDelta[1] = RIJ.getY();              m_InitialVectorIDelta[2] = RIJ.getZ();   }  if(m_BondStatus[0] == 1.0) {            rij_0 = CSimple3DVector(m_InitialVectorI[0], m_InitialVectorI[1], m_InitialVectorI[2]); //initial vector             double a_par = rij_0.length(); }
    Altair Employee
    Thanks Stephen,
    Hi Raheem,
    That looks correct to me so long as you are using rij_0 per bond.
    Just to note I don't think that this is doing anything with the code as shown:
    As you are declaring this inside the bracers {} as soon as this is closed with } anything declared within these brackets is deleted.  As you have declared rij_0 outside the brackets shown this will continue to exist.
    Regards
    Stephen
    OP
    Hi Raheem,
    Regards
    Stephen
    Hi Stephen,
    Because the force and torque calculation are in the bracers{}, and double "a_par" was easy for me to read the code.
    rij_0 was declared outside the brackets, and I know it will continue to exist, but it seems no difference here to define it inside or outside the brackets, until now, no bug happens to me.
    And I post this question because when I rerun the simulation, the broken behaviour of bonds was difference. The strength for each bond was the same. So I am doubt may some bond properties given to each bond changed over the time.
    Regards!
    Raheem
