Material in Inspire Cast
Brian_20847
Brian_20847 Altair Community Member
edited December 2022 in Community Q&A
Hi expert,
I have a question about when I created new material. In Inspire Cast what material parameters are most important for cast part and mold (I have to enter all material parameters)? Besides, when I use advanced meshing with SimLab tool, What is the basis for choosing the optimal mesh size? Can I run low-pressure die casting for steel material? Because I see that they recommend using other materials.
Best Regards,
Tuan.
Answers
  • MilanRaval
    MilanRaval
    Altair Employee
    Hello Pham Tuan,
    When you create new material, please try to put/ add all the material properties asked in the Inspire Cast material editor. You do not need material composition data.
Welcome!
Welcome!
