*** ERROR # 4903 *** TABLES1 bulk data entry ID=1 has a segment that corresponds to zero or negative hardening.
Altair Community Member
Updated by Theo_21327
Hi All,
I used SimLab 2022 to follow the tutorials "OS-SL-T: 1000 Nonlinear Analysis of Rubber Ring" but failed with errors.
The .out is attached below. ID=1 is the rubber material which is imported from "Rubber_Material.xml" file.
There were 3 error messages during input processing. The first message is repeated below: *** ERROR # 4903 *** TABLES1 bulk data entry ID=1 has a segment that corresponds to zero or negative hardening. Make sure that x-value in TABLES1 entry is stretch ratio, not engineering strain (stretch_ratio = 1.0 + engineering strain). *** Run terminated because of error(s) in the input data.
After reading the file, I found that I can use " PARAM, CHECKMAT,NO" to bypass, but I did not find this in the "PARAM". Only "CHECKEL,NO" can be found in "PARAM".
NOTE # 1599 3 stability-related material property errors found. To bypass checking these errors use PARAM,CHECKMAT,NO. This may, however, cause zero or negative pivots and excessive compliance.
Does anyone know how to sort out the errors? I appreciate your help in advance.
Regards
Theo
