🎉Community Raffle - Win $25
Join and Win
Optistruct CPU Default
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hallo Guys,
How many CPU is used as Default in Optistruct Simulation?
1 - 5 of 51
    Altair Employee
    OP
    If thre'is no supplementary parameter, only ONE cpu will be used, I think.
    Altair Employee
    OP
    can you please explain more? my Desktop Properties are:
    Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz
    Ram 16 GB
    64 Bit
    how can i fasten the analysis which tricks can be used rather than modelling tricks?
    Altair Employee
    OP
    Have a look at my screenshot. With parameter '-nt 4' your job will be calculated with 4cpu in SMP mode.
    Altair Employee
    OP
    With the standard direct solving method parallelization is not efficiently used....use PCG Solver (iterative) for linear static analysis e.g. to fasten your analysis A LOT!
    Load collector --> card image 'SOLVTYP' --> PCG --> Load Step --> SOLVTYPE ...
    Altair Employee
    OP
    Thank you both. excellent explenation. sorry for replying late!
