How to creat 2D element from nodes
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi, everyone
i'm a beginner in Hypermesh. Recently, i've encountered a problem in 2D meshing. I  have 3 nodes (like in the photo below). I want to create a trias element from them, or creat some lines from them, so i go to Mesh - create - 2D element - Element. I chose those 3 nodes, but no element was created!!!
So could anyone tell me where i was wrong and how to fix this, thank you very much!!
1 - 14 of 141
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    F6>create
    select 3 nodes and click middle mouse button (or click 'create')
    Altair Employee
    OP
    hi Tinh. I did exactly what u told, but after i choose 3 nodes, there is a message: select mid-side nodes, and after i click Create, there is a message: select conner nodes. And nothing was created
    Help me!!
    Altair Employee
    OP
    Maybe your mesh is 'tria6' (2nd order), not 'tria3'. So in this case, you need define 6 nodes.
    Altair Employee
    OP
    thanhk u Q.NGUYEN_DAI, it's ok now :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    Altair Employee
    OP
    @Q.NGUYEN-DAI, i just run into the same problem, when i deleted 1 element and i want to creat a new element to patch, i could not create any element. when i choose the first 2 nodes, they are highlighted, but when i choose the 3rd nodes, all nodes are not highlighted anymore. so no element was created. I've attached my model below, could u take a look and help me know what exactly the problem is!! Thank you
    Altair Employee
    OP
    Your mesh is 1st order, so for surface mesh, you need only 3 nodes for each element.
    Attention 1: when you create element, have a look at CURRENT component, because new elements will be created on that.
    Attention 2: Your current mesh is not so good. For TET4 meshing, you have to make finer mesh to get better results.
    Altair Employee
    OP
    thank you @Q.NGUYEN-DAI, now i know where i was wrong :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' /> . I'll try  to make my current mesh better. But you know, i am a beginner in Hypermesh, so could you give me some advices, some tools on that, i mean on making finer mesh, thank!
    Altair Employee
    OP
    For shell-like structure like yours, if you want to work with TET4 solid element, you need at least 3~4 elements on thickness to have acceptable results.
    Altair Employee
    OP
    but the thickness of my model is  <2mm, very thin, as my plan, i will mesh the shell with second order trias element, then use Mesh - Tetra Mesh to make solid, will it be ok???
    Altair Employee
    OP
    Even with 2nd order element, you have to make some elements on thickness. Only one element / thickness can not give you acceptable results.
    Why not calculate with shell elements?
    Altair Employee
    OP
    I agree, I would calculate with shell elements.
    However, I have tested this myself. I created a simple model of a cantilever beam and compared different solid meshes with the max output von Mises stress result.
    Via hand calculations (baseline): Stress = 600 MPa
    1x HEX8 element through thickness: Stress = 565 MPa
    2x HEX8 element through thickness: Stress = 604 MPa
    1x TET4 element through thickness: Stress = 154 MPa
    2x TET4 element through thickness: Stress = 387 MPa
    1x TET10 element through thickness: Stress = 623 MPa
    The results are a bit iffy because the max stress is located near the constraints (I should've done this using a 3-point bending model...) You can clearly see here that TET4 elements are bad at calculating stresses through the thickness due to bending. However the TET10 element (with midside nodes) is a lot better.
    Still, for best results calculating stresses through the thickness I would be using HEX elements (where possible) for thick components and QUAD elements for thin shell components.
    Altair Employee
    OP
    thank u all, i will try to mesh with hexa element!
    Altair Employee
    OP
    Hi
    I have the same problem.
    Tried creating the element...
    But when I select the third node, the nodes are just unhighlighted and no element is created.
    So what should I do?
    User: "Dipen Panchal"
    Updated by Dipen Panchal
    Hi
    it will be great if you can send full screenshot... but for now I am assuming that your current component is different than where you are adding element. So please try with setting current component. For changing current component click on 'set current component' and choose appropriate(find attachment).
