Altair RISE
Nominate Yourself Now!
Importing FEM of part into Assmebly
User: "Kiran1986"
Altair Community Member
Updated by Kiran1986
I had FEM of one part A.
Is it possible to import that FEM 'A' into a CAD assembly so that the FEM will come directly to related CAD part 'A'.
For example:
Assembly C has Sub assembly B, inside sub assembly B, i had Part A.
When i import FEM of Part A, is it possible to directly import it as a component inside sub assembly B ?
1 - 4 of 41
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    I don't think you can do that with importation. But :
    • I can move part into desired Assembly manually
    • I can write some TCL code to do this task
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    There is a Part Browser that controls this kind of behavior.
    You can hva eyour parts organized into a interchangeable organization, and change one model by another, keeping its assembly structure.
    It is also compatible with BOM from plm.
    But in your case as you're importing a 'flat' model it will not be possible direct.
    Take a look at the help section for part browser and its tutorials i the help.
    User: "Kiran1986"
    OP
    Can i have any TCL code for reference ? Thanks in advance
    Firstly, maybe you can try it in interactive mode?
