Importing FEM of part into Assmebly
I had FEM of one part A.
Is it possible to import that FEM 'A' into a CAD assembly so that the FEM will come directly to related CAD part 'A'.
For example:
Assembly C has Sub assembly B, inside sub assembly B, i had Part A.
When i import FEM of Part A, is it possible to directly import it as a component inside sub assembly B ?
There is a Part Browser that controls this kind of behavior.
You can hva eyour parts organized into a interchangeable organization, and change one model by another, keeping its assembly structure.
It is also compatible with BOM from plm.
But in your case as you're importing a 'flat' model it will not be possible direct.
Take a look at the help section for part browser and its tutorials i the help.
I don't think you can do that with importation. But :
