🎉Community Raffle - Win $25
Join and Win
RBE3 - Slave node with Boundary Condition
IRA_EM_21281User: "IRA_EM_21281"
Altair Community Member
Updated by IRA_EM_21281
Hi Folks,
I am curious how the solver finds a solution when the dependent node (slave) has a boundary condition Uy=0 at the SPC shown in blue. See attached.
In the case of a rbe2 element, it is clear that the independent node (master) would have the BC Uy=0 and thus the dependent node set can be solved for.
Any comments?
1 - 2 of 21
    that's exactly why you cannot apply a BC in RBE3. You will be generating kinematic conditions conflict, thus an error.
    For constraining a RBE3 dependent, you could use as a workaround, create a CBUSH attached to the RBE3, with RIGID stiffness, and ground the CBUSH node.
    OP
    That's what I thought but the model solved successfully and so I looked into it further. It seems Optistruct uses PARAM, AUTOMSET to switch the dependent to an independent
    Now I am wondering does the element still behave as an rbe3?
