Altair RISE
Nominate Yourself Now!
Increase in demand on Models containing Contracts with Friction
User: "Andy@LamteqSolutions"
Altair Community Member
Updated by Andy@LamteqSolutions
Hello,
I have been having issues with a model containing contacts and friction. The model is relatively straight forward, a multiple mast model with wearpads and contacts between pad faces and adjacent mast sections.
When the contact is set to property type slide N2S, the analysis demands around 47GB for In-Core Solution. However when the type is set to static friction coeff = 0.15, the in-core demand becomes 80GB. The model on my pc then typically fails because MUMPS demands significantly more RAM.
I've tried adjusting the search distance and using a PCONT card to define friction with little impact on MUMPS demand.
Any suggestions?
I currently have one PARAM card... PARAM,EXPERTNL,CNTSTB
1 - 11 of 111
