Radioss Run Error
Hi,
I am facing an error while running a job on Linux Cluster. I have kept both files 0000.rad and 00001.rad in the same folder and used the radioss-gui for submitting the job.
The following error is coming on submitting the job. The solver is not detecting the 0001.rad file. Verision is 13.0
Hi Rahul,
Thank you for your prompt reply.
I have done with both methods i.e by merging both files and also taking them separately.
However, the error still persists.
The following is the commad line used:
-mpi i -np 16 -hostfile /gopal/Rollover_Merged/machine -mpipath /opt/intel/impi/4.1.1.036/bin64
The folder: Rollover_Merged consist of the starter and engine files along with the host file.
Hi,
There was an issue with MPI and the compute node was not recognizing where the deck files are present.
It has been solved.
Thank you for your support.
hello,
i have completely situation with (please see the picture i send you), i want ask how to solve MPI issue?
this problem troubled me a lot, really need your help!
thanks very much
shuangshuang
Hi,
Error clearly shows that engine file not found.Before exporting file in Hypermesh make sure that option is set to merge starter & engine file.
Regards
Rahul R
