Error iD:760
i am trying to carry out dynamic explicit analysis while solving i am getting this message
.. BLOCK FREE FORMAT
.. STARTER RUNNING ON 8 THREADS
.. CONTROL VARIABLES
.. UNITS SYSTEM
.. FUNCTIONS & TABLES
.. MATERIALS
.. NODES
.. PROPERTIES
.. 3D SHELL ELEMENTS
.. 3D TRIANGULAR SHELL ELEMENTS
.. SUBSETS
.. ELEMENT GROUPS
.. PART GROUPS
.. NODE GROUP
.. INITIAL VELOCITIES
** ERROR TRAPPED : REPORT TO LISTING FILE
ERROR ID : 760
in output file all i could found was this,( 962 is the last component )
962,prop_ashaft
RANDOM NOISE
| ABNORMAL END |
| Segmentation Violation |
| TRACE BACK : |
INITIAL VELOCITIES
ERROR ID : 760
** ERROR TRAPPED
thanks in advance
HI,
Assign PART card image to component(s).
Right click on component(s) in model browser>> Edit>> Card Image>> PART and apply the changes.
Once done, run the job and let us know if you are through the error
