The test does not run due to a unknown error. It shows the ticket numbers but I can not find the meaning of these numbers.
Ticket Number : #100.18.11 #100.18.10 #100.18.1 #100.18.39
Thanks in advance for helping me
Hello Thymen;
Can you please share the zip file generated by FluxMotor for this test ?
So we can find the error message, and your FluxMotor project.
Regards
Hello Thymen; Can you please share the zip file generated by FluxMotor for this test ? So we can find the error message, and your FluxMotor project. Regards
Please find in attachment the zip-file. I hope this is what you are looking for
Hi Thymen;
The issue is due to a bad setting of your magnet.
you used a verry small length here
If you use 0.5 mm it should work now.
