Hi
I am also facing the issue with opening the STP files. The STP is genetrated from Hypermesh.
The surfaces are getting splitted or it is failing to import.(Tried with both CAD and aslo CAD through Translation).
And we are not getting the same IMPORT STEP options that you have mentioned in the first post.(Mainly Method:)
Iam using SL19.1 on windows platform.
Hi
In general, I would strongly recommend to export PARASOLID files from Hypermesh into SimLab.
Starting from v14, HM PArasolid-Export has improved a lot and I would surely recommend it as a interface to SimLab, instead of Step.
Just make some attention to the Units, sometimes HM will export it scaled x1000
Thanks
Hi,
These are different readers available in SimLab to import STEP models. STEP models are translated models. So, we need to choose the STEP reader according the STEP model. If the STEP model is written from CATIA software, then use SimLab reader to import. If the STEP model is written out from other system, then my suggestion is to go with either 'Convert to Parasolid' or 'External reader'.
