🎉Community Raffle - Win $25
Join and Win
license error, i can use hypermesh and radioss for starter but it gives error for engine
Good afternoon,
I have a license error trying to run a radioss simulation, i can use hypermesh and radioss for starter but it gives error for engine: see next
LICENSE ERROR
Altair Hosted HyperWorks Units: License error
Feature:Radioss
Error Code: -40
Error Description:
[LicID 52031] AU Mechanical Engineer - (Err: -10) While checking out feature "GlobalZoneEU": Not enough features available (Only 21000 features available.)
[LicID 54241] AU Mechanical Engineer - (Err: -40) While checking out feature "GlobalZoneEU": Requested feature name was not found in licenses
Feature: HyperWorksEDU
Error Code: -40
Error Description:
[LicID 52031] AU Mechanical Engineer - (Err: -40) While checking out feature "HyperWorksEDU": Requested feature name was not found in licenses
I have the machine authorized in altairone website  so i don´t know what more to do to fix the problem, I have contacted the IT responsible but I dont get an answer yet..
thanks in advance
Ignacio
1 - 1 of 11
    Hello,
    Per this error message:
    You did not have enough available units when you tried to start Radioss. Radioss requires 30+ units (depending on the number of cores you specify) and you only had 21 available at that time. Please free some units and try again.
    Thanks,
    Matthieu Pupat
