License error 9 during fatigue analysis
Hi, while running a uniaxial stress-life fatigue analysis during fatigue analysis with OptiStruct intermediate examination I get the license error 9.
Also, checking the license setting I have noticed the same error 9 despise of the license is activated.
However, I have already tried all the tips to fix this issue (listed below), I am still getting the error 9 and I cannot complete the certification.
- check the Ethernet ID:
- license file name and location:
- add the variables
-requested new license
Can you help me, please? what should I do?
thanks
Hi,
Please try to uninstall the software completely from your system and reinstall it again.
To make sure the file is not damaged on download, run an md5 checksum on the downloaded file (just google md5 checksum). Refer this for instructions -
Hi Payal,
Thank you for your response.
I am struggling to find the installer checksum from Altair Marketplace. Could you address me to find it, please?
thanks
Hi Payal,
thanks
Hi,
Can you let me know which Altair product are you using? And the version of the software?
Also run md5 checksum on your downloaded file and share the value here so that I can check if it matches with the correct value.
Hi,
I have just followed your instructions (uninstalled the software, deleted the file.exe, downloaded a new file.exe, reinstalled and checked the checksum) but the error 9 has not been fixed.
I really need help!!!
Any help is appreciated.
thanks
Can you once check/confirm whether the Ethernet ID of your machine matches with the one in the license file?
Please also refer to this to know about the student edition limitations - https://altairuniversity.com/altair-student-edition-limitations/
Hi,
the Ethernet ID matches with the license.
C:\Users\SLL638>getmac/v
Connection Name Network Adapter Physical Address Transport Name
Ethernet Intel(R) Ethern 98-E7-F4-EF-BA-BE Media disconnected
Wi-Fi Intel(R) Dual B B8-8A-60-FA-EB-37 \Device\Tcpip_{6AAD0B20-AC50-472C-BC73-658C74252312}
Ethernet 2 Cisco AnyConnec N/A Hardware not present
Bluetooth Netwo Bluetooth Devic B8-8A-60-FA-EB-3B Media disconnected
SHARE = VIRTUAL
COMMENT = " Server Info: ETHERNET = B88A60FAEB37"
SN = "D435EB44-110B-11EE-B0BE-E4B4A80B4B5215"
KEY = 69HJMRP37SLJ907CIM7HKJBNFR000DM8RGGKAP8R3HM0BA96AQ2ABUGM149TTOLOL3OAQS
Thank you
Hi,
https://community.altair.com/community?id=kb_article&sysparm_article=KB0117361&sys_kb_id=5e2d7fc8db8b9950cfd5f6a4e2961925&spa=1
