🎉Community Raffle - Win $25
Join and Win
prop/spring/type4
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm new here image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>.
How is the function ('[funct_ID1] Function defining f') defined? What variable is on the x-axis and what is on the y-axis?
Is it possible to built a limiter with this spring type?
Thanks for your help!
1 - 2 of 21
    Altair Employee
    OP
    Hi,
    fct_ID1:
    Function identifier defining f depending on flag Ileng...
    Ileng: Input per unit length flag (Integer)
    = 0: force in the spring is computed (see Comment 6)
    = 1: all input are per unit length (see Comment 7)
    there a a lot of comments in the solver manual.
    Y - Force
    X - delta l
    Regards,
    Mario
    Altair Employee
    OP
    Thanks for the help and the informations, I'll try it!
