ERROR # 1418 optistruct analysis on Linux server
Hello,
I am trying to run an optistruct analysis on a remote Linux server but i always get the following Error message. Even an Optimization that runs easily on my local machine (Surface Pro 4) gets this ERROR on the Linux server.
I know this was alerady mentioned in a similar post on this forum, but deleting the control cards was not helpfull.
I am starting the Analysis over the Linux command prompt:
sudo sh <file_path>/2019/altair/scripts/optistruct <file path input data>
*** ERROR # 1418 *** in the Input data:
Control Card without the name in the first field.
(Possibly missing trailing comma in the preceding card,
missing BEGIN BULK card or line before BEGIN BULK has trailing comma.)
- You can do analysis under normal user, sudo is not needed
- Try: dos2unix your_file.fem and run again?
Hello,
Hello Maxx,
Maybe it's due to CTRL-M char, when you import a text file from MS-DOS (Windows), and forget to transfer it in ASCII or text mode ...
Can you please share the *fem file. I want to test it
Cheers,
