Flyback Control using UC3844
Hi All,
I am trying to control Flyback Control using UC 3844. I am using app note for the same. However, when simulating the circuit. The sytem only works fine if both the input and output are on same ground. How can we simulate with different grounds since Flyback converter is supposed to give isolated output
1 - 5 of
51
Please post your schematic. It is likely that something odd is happening. It could be that you are using the "node to ground" voltage probes instead of the node to node probes when your secondary is isolated.
If you are using the node to ground then you will get garbage waveforms when the secondary is isolated.
