How to show decimal Value in Contour Load?
1 - 5 of
51
I tried and cannot right-click mouse on legend to change.
I think we have to set up in option but I don' know where
Normally, nothing needs to be set up. Which version do you use? Did you click directly on the legend itself?
Thank @Ingeniorator and @Adriano Koga
My Problem is deal with "Contour Load" option in HyperMesh, and not color range in HyperView.
I use HW2020.1, and I still haven't yet found solution for this problem.
Thanks so much
Best Regard
You can right-click on the legend and change the numeric format, or go in the legend editing interface and specify the numeric precision yourself.
