🎉Community Raffle - Win $25
Join and Win
TSTEP is automatiocally adding in nonlinear quastatic analysis
User: "mpvnaresh"
Altair Community Member
Updated by mpvnaresh
Hi
I am rinning a nonlinear quastatic analysis . I am putting it for solve its giving an error
 *** ERROR # 1461 *** in the input data:
 Card 'TSTEP(TIME)' is not allowed for this subcase type.
 the input data TSTEP is adding on its own .how to deactivate this .?
1 - 10 of 101
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    there is no TSTEP entry for nonlinear quasistatic analysis. Make sure you are choosing the correct analysis type- it should be non-linear quasi-static not generic.
    User: "Pranav Hari"
    Updated by Pranav Hari
    Check this video also. See the load step creation after 8:00 min
    User: "mpvnaresh"
    OP
    Sir i am not adding TSTEP s I t is automatically adding up in the deck file .
    The NLPARM and TSTEP load collectors share the same ID (3). Each LC needs a unique ID, which might be causing the error.
    User: "mpvnaresh"
    OP
    But i am not adding the time step . I dont know why it is adding in all the solutions.
    When iclick on optistruct to solve ,In the deckfile TSTEP is being created.
    User: "mpvnaresh"
    OP
    After i deleted the .tcl and hm.setting files from My Documents the problem got resolved .
    Thanks for the support.
    User: "FaroukM"
    Updated by FaroukM
    Hi
    Hi !
    TSTEP is for transient analysis.
    If you want to run Non Linear Quasi Static Analysis, NLPARM is sufficient :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Best regards ,
    User: "mpvnaresh"
    OP
    Hi All
    I did not create any TSTEP .I created a Non linear Quasistatic solution ,and exported(solver deck file).
    In the FEM file i observed a TSTEP card  is added.For all the solution (Liner or Nonlinear )TSTEP is automatically added in the deck file.
    After i delete the .tcl and .settings file from the documents , The problem got resolved.
    User: "Deepak525"
    Updated by Deepak525
    Pleace help me to solve this problem
    tried this step also it doesn't work  kindly help me
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Please make sure to set the analysis type as nonlinear static instead of generic in loadstep.
