Altair RISE
Nominate Yourself Now!
INTERNAL ERROR in ESLM when buckling (LAMA) constraint included
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
The following internal error occurs only when I include linear buckling constraint in ESLM.  Does it mean linear buckling responses are not allowed inside ESLM nonlinear response optimization?
When considering traditional linear responses e.g. stress, displacement from linear subcases together with nonlinear responses, ESLM works fine for my application,
*** ERROR # 266 ***
 Specified matrix number 1 out of allowed range (1-0).
 *** INTERNAL PROGRAMMING ERROR ***
   in file 'fiospa_new.F', at location # 1362.
       ioerr(1) =         13
       ioerr(2) =          1
 ****  ABORTING RUN DUE TO AN INTERNAL ERROR  ****
Solver FAILED
input (*.fem), output (*.out) and *.stat files are located at:
Regards,
Tanut
P.S. HW Solvers 13.0.210 version was utilized.
1 - 15 of 151
    Altair Employee
    OP
    Hi,
    I am checking with the developers on this. I will get back to you ASAP!
    Altair Employee
    OP
    Many thanks Prakash!
    In case an older version works well with this type of application, please recommend it (plus a way to download it) to me.
    Regards,
    Tanut
    Altair Employee
    OP
    P.S. Optistruct 13.0.210 complains an internal error when running ESLM optimizaiton with several loadcases. I have to get back to 13.0.0.98 to avoid this.
     ANALYSIS COMPLETED.
       Access DSET 'B2Bigridexp' for wrong record 3 (only 2 exist)
     Error message 2 from operating system:
    No such file or directory
    Altair Employee
    OP
    Dear Prakash,
    May I ask if there is any update on this matter?
    Regards,
    Tanut
    Altair Employee
    OP
    Hi Tanut,
    Our developers are looking into this issue.
    Altair Employee
    OP
    Thanks Prakash, please let us know whenever this problem is fixed.
    Tanut
    Altair Employee
    OP
    Hi,
    For now there is a workaround to get rid of the error.
    Include PARAM,ALTBUCK,0  in the deck. Edit the solver deck with notepad and supply the  PARAM,ALTBUCK,0 as shown in the attached image.
    Note: The ALTBUCK card cannot be accessed through GUI. It should be manually supplied in the deck.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-00089300-1431508460_thumb.jp
    Altair Employee
    OP
    Thank you Prakash!
    It works but not completely.
    When I have other constraint e.g. displacement limit for nonlinear loadcase in addition to buckling constraint (LAMA), I get this programming error:
    START RUNNING MODULE :  NLGSLV ...
       in file 'xresults.F', at location # 1058.
    Please see my input file in your Dropbox: V512_RF_COMP_M_11.fem
    Altair Employee
    OP
    Hi,
    I shared a file with you. Please use that and check if you still get the same error.
    Altair Employee
    OP
    I still get the same error, so I should check your Optistruct verison.
    Mine is
     OptiStruct  Version 13.0.210.001
     Time of build : 23:21:01
     Date of build : Jan 12 2015
     Build tag     : 0751393_5533130_Ce64RBW8UH12M:96526
     Supported H3D : v12.0
     Radflex name  : radflex_13_win64.exe
     Use version : 130131112 or higher
    Altair Employee
    OP
    Hi,
    I have the same version
    Can you try the same model on another machine?
    Altair Employee
    OP
    FYI,
    attaching the .out file
    Altair Employee
    OP
    Many thanks Prakash for your great support but I think we are mixing up TWO models here...
    The test.txt file you just sent above does not reflect my problematic model. So, I attach the file I am struggling with here again:
    https://www.dropbox.com/sh/0nqezeb8q95cbf1/AACjXJYzpkCudD8KOG0Sz2Gva?dl=0
    If you can run the attached file, please let me know.
    Many thanks,
    Tanut
    Altair Employee
    OP
    Hi Tanut,
    I think yes, sorry about that.
    I checked with experts and suggested to remove the CSTRESS= ALL output from implicit dynamic subcase (make sure PARAM, ALTBUCK, 0 is still available).
    I ran withtout CSTESS and the analysis is through the error.
    Altair Employee
    OP
    Thank you so much Prakash!
    It went well.
    Tanut
