HOW TO RUN HYPERMESH CFD IN BATCH MODE?
Hi everyone,
i'm trying to create a script loop where i have to run hypermesh CFD in batch mode. I've already written the TCL code and if i put it directly into the TCL Comand on Hypermesh CFD it works without any problem.
But when i try to run Hypermesh CFD with the TCL script from batch (cmd) with the following command (C:\Program Files\Altair\2023.1\hwdesktop\hm\bin\win64\hmbatch.exe" -tcl "C:\Users\enrico.lorenzi\Desktop\Lavoro\CFDTrial\Iteration5\Comand_Script.tcl) it returns me errors (image attached below) because it doesn't recognize the commands contained into the tcl script .
Seems as running hmbatch.exe start a session of hypermesh but not a session of hypermesh CFD so it doesn't recognize the hypermesh CFD comands. Is there a specific comand to run hypermesh CFD in batch mode from cmd?
Thank you,
Enrico
If you are able - please attach the script itself, as well as the files (geometry, etc) the script accesses.
