Error on tutorial RD-3597
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi
I am learning the drop test simulation from tutorial RD-3597 from Hyperworks 13.
1.
I followed every step in tutorial but there are errors when running radioss. When I ran the CELLPHONE_0000.rad file in the <installation_directory>\tutorials\hwsolvers\radioss>, it also failed.
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-47062000-1439752847_thumb.j
2.
Apart from that, from hyperview, which files should I choose to exam the result?
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-84219800-1439753108_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-85331800-1439753166_thumb.j
Regards,
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-12201200-1439838846_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-03239800-1439838849_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-91848400-1439838851_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-86013000-1439841921_thumb.j
1 - 4 of 41
    Altair Employee
    OP
    Hi,
     please assign PART card image to components and run the analysis
    Altair Employee
    OP
    Hi,
    Hello, Prakash
    Thank you for you reply. Three components have already been set as parts.
    <?xml version="1.0" encoding="UTF-8"?>post-39070-0-12201200-1439838846_thumb.j<?xml version="1.0" encoding="UTF-8"?>post-39070-0-03239800-1439838849_thumb.j<?xml version="1.0" encoding="UTF-8"?>post-39070-0-91848400-1439838851_thumb.j
    But it still occurs the same errors.
    1 When I followed the tutorial step by step, it reported the error as following
    2 From the tutorial, Step 4:  Create material and properties for the cell phone parts
    point 6, Click fct_ID1 and select stress_strain_curve (the function curve previously created).
    But I could not find the fct_ID1, and I used fct_ID_E instead.
    Regards
    Altair Employee
    OP
    Hi,
    I can see that the curve definition is not correct for material,
    Could you please share the model with us?
    You can use the dropbox link in my signature below to share the model.
    Altair Employee
    OP
    Hi,
    Curve should go to Stress-Strain function definition.
    Card edit the material>> N_Func>> 1 >> click on fct_ID1 and point the curve here.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-10908300-1439953432_thumb.jp
