SimSolid fails to identify faces of larger sized STL models
Hi there,
I am facing problem in selecting the faces of larger STL models to apply boundary conditions. SimSolid successfully identifies the faces of smaller STLs but fails for larger models. Changing the geometry import settings did not help. I am trying to determine the strength of TMPS sheet-based structures. Is there any limitation of STL model size for face recognition to work? or am I missing somthing here?
Thanks and
Best Regards,
Mudassar Khalil
