How to correct the failed surface mesh part of a STL file
Dear all:
I am a doctor and just learned some basics of hypermesh from my friend. I am planning to use Abaqus to analyze the airflow in the nasal cavity, however, I have some problems in the surface meshing process. I already tried to smooth the original contour of the STL file, but still have some failed surface meshing part (about 4.4%). Is there anyway I can correct or adjust the nodes to make the failure rate to 0 % ? It would be really tiring to use the 'place nodes' function for thousands of times. Then I can go to the 3D mesh process inside and do numerical analysis.
Is there a video on youtube or some tutorials online?
Thank you very much if there is any tip that can help me.
Thank you very much for your prompt reply. I have tried this method and the result seems good.
But I would like to know that is the mesh created with shrink wrap method is also a surface mesh ? or as your have mentioned above, it is already a 3D mesh with tetrahedron~
Also, after using the shrink wrap method, it created some extra meshes (the red ones), is it possible to manually remove some of them (like those I am pointing with a white arrow)
Thanks again !!
Hi,
If objective is to generate tetrahedral mesh on cavity.Then i would suggest to give a try with shrink wrap with all tetra option.I know your current process is too time consuming but you can give a try with this approach.Also please refer similar topic on below support forum post.
