Boundary condition
Harsh2610
Harsh2610 Altair Community Member
edited October 2020 in Community Q&A
Hiii
I want to run an analysis for a bottle bearing load of 100 Kg for 24 hrs. which boundary condition I have to use?
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2017
    Hi,
    You can try by creating a rigid impactor, where you can assign the mass, and apply the imposed displacement to the rigid impactor.
  • gopal_rathore
    gopal_rathore Altair Community Member
    edited June 2017
    Hi,
    It seems it is a static load case.
    If the load remains throughout the time., you can consider it as a static analysis and use optistruct where give a lumped mass of 100 kg using rbe3 element. Make the bottom of the bottle constrained considering it is rested on ground or apply relevant constraints as per the physical environment.
  • Harsh2610
    edited June 2017
    Hiiii
    George, I need more explanation about this.
    How can I apply displacement to this?
    How should I get Bottle behaviour after 24 hrs of laoding?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2017
    Hi,
    As Gopal suggested above, this is a static case and you have to try the same in OptiStruct.
  • Harsh2610
    edited July 2017
    Hi,
    how can i get bottle behaviour at 24th hour??
  • gopal_rathore
    edited July 2017
    Hi,
    The result of static analysis is independent of time. Thus, whatever the result you get in static run can be considered for the result at any time .
Welcome!
Welcome!
