🎉Community Raffle - Win $25
Join and Win
Change Soft convergence criterion
Hello,
when i start an optimization with optistruct the calculation is finished after 1 Iteration. In the Output-file i found following Information:
Soft convergence criterion satisfied;
the design did not change during the last Iteration.
What does this mean?
I already did a lot of successful shape-optimizations but in this case i don't really know why the shape didn't change.
I changed the default OBJTOL value from the opti control card but the problem still occurs.
The most interesting thing is:
When i change the inital value in the shape panel to 0.5 I don't have any problems and the optimization finds the best shape. When I start with an inital value of 0.0 then i get the problem with the soft convergence criterion.
Thank you
Greets,
Fatih Uysal
1 - 3 of 31
