RBE 3 elements
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
can anyone tell me what is error #339 in case of RBE3 conditio. It is saying that' The dependent d.o.f is constrained by grid or spc data. Please reply.
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2016
    Hi Bhushan,
    RBE3 are meant for load transfer and the load is applied on dependent node.
    In your case the dependent node is constrained and this is causing a problem.
    Remove the SPC on the RBE3 dependent node and try again.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi prakash,
       What should be done if I want to apply constrained to RBE elements. I have created RBE3 element by finding nodes between extreme two nodes. what should be done if I want apply constraint to dependent node so that it will be applied for other independent nodes.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Bhushan,
    Change RBE3 to RBE2. Go to 1D>> COnfig edit>> select the RBE3 and select new config to RBE2 and click Switch.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    hey prakash,
    RBE2 option is not coming after clicking new config.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Try Rigdlink instead :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Welcome!
Welcome!
