🎉Community Raffle - Win $25
Join and Win
Extracting Bolt (Beam) forces for Bolt Calculations
daradUser: "darad"
Altair Community Member
Updated by darad
I've created an solved a small assembly with bolted connections, with its contacting face 'separated' for the bolt calculation.
Question:  How can I extract  bolt forces (Axial, Y-shear, Z-shear) for entry into the spreadsheet.
Comment:  When using the Property feature to create Beam properties, the Calculate function computes the four entries with minus (-) sign, which had to be manually edited to (+) sign for Optistruct to solve.   I had simply entered the value for R2, but not R1.   (SimLab 2017)
1 - 6 of 61
    daradUser: "darad"
    OP
    Updated by darad
    Rather than extracting element bolt forces (BAR) for x, y, z via the Simlab results display, or Hyperview display, a more efficient method is to simply ASK FOR IT in Simlab.   Output is written to the *.force file.
    Insert a text file for Input/Ouput
    ELFORCE(OPTI) = 900, where 900 is desired SET ID
    Insert a text file for bulk data
    SET     900     ELEMENT LIST
    +       199036  199038  199040  199042  199044  199046
    +       etc
    *.force output file:
     ITER    0    1        1         6 LOAD:       8 (LOAD) Load 20 000 lb    BAR #-END  AXIAL      SHEAR-1     SHEAR-2     TORQUE     BENDING-1   BENDING-2   199036-A -7.3239E+04 -6.3574E+04  2.0407E+04  2.0429E+05 -1.6279E+06  2.3561E+05   199036-B -7.3239E+04 -6.3574E+04  2.0407E+04  2.0429E+05  2.5625E+06 -1.1095E+06   199038-A -1.2324E+04 -4.9177E+04  2.5647E+04  3.5277E+05 -1.6517E+06  2.9854E+05   199038-B -1.2324E+04 -4.9177E+04  2.5647E+04  3.5277E+05  1.7521E+06 -1.4766E+06   199040-A  2.3169E+04 -3.6805E+03  5.7895E+03  5.0671E+05 -1.8987E+05  8.1687E+04   199040-B  2.3169E+04 -3.6805E+03  5.7895E+03  5.0671E+05  4.4348E+05 -9.1460E+05 etc.
    KamalrajUser: "Kamalraj"
    Altair Employee
    Updated by Kamalraj
    Hi,
    Inserting these text can be done directly in SimLab Itself. Go to LBC browser > Loads and Constraints > Right click > Text Data. All unsupported cards of SimLab can be added here and it will get exported in deck in corresponding field.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7c975f36f4fc2497c599183e67e640bd.png
    daradUser: "darad"
    OP
    Updated by darad
    Yes, after I inquired locally and hwsupport for the best process to extract was via the GUI.   Rather painful.   Now nearly automated via Optistruct fem input.
    With regard to Simlab SET definition, I was surprised one could drag-select a half dozen or so entiities -- EXCEPT for BAR elements.   Why not?  Just display BAR elements, and drag-select the group when definiing a SET (to be exported into the fem input file)
    Ditto for summary of applied forces and reaction forces, just add input/output text
    OLOAD
    SPCFORCE
    and in Hypermesh there is a checkbox for OLOAD and SPCF, which would likely have same result.
    daradUser: "darad"
    OP
    Updated by darad
    Can Altair respond to why BAR elements cannot be graphically drag-box selected to define a SET?   And add to Bulk Data.   Then the user only needs Case Control:  ELFORCE(OPT)=[set-id]
    Please add to the set of entites to define a SET, Simlab 2020 is not too late.   More useful that defining RBE2's to a SET.
    Altair Employee
    Updated by Kamalraj
    hi,
    Hope you are trying to pick bar element after opening set dialog. It wont work, Since SimLab not support to assign SETs for Bar elements or bodies. Please let us know the use case and priority of this request, based on that will support to add set for bar elements.
    Also, SimLab already has support to select the bar bodies or bar elements in rectangular selection / drag box selection. Please refer the attached video.
    Thanks & Regards
    KamalRaj
    Senior Application Engineer – SimLab
    Altair | Nasdaq: ALTR
    kamalraj.rajagopal@altair.com | altair.com
    Connect with us: LinkedIn | Twitter | Facebook
    daradUser: "darad"
    OP
    Updated by darad
    For some reason, even with BAR filter, the selection of individual elements did not always work.  Sometimes.   And did not work for drag-box selection ever.   Must be a screen graphic issue.
