angular velocity in optistruct
I am modelling a bearing and doing its analysis in optistruct. However, I am having a problem in imposing angular velocity onto the inner race. I wanted to know is it possible to use the impvelb card for providing angular velocity to the inner race?
If yes, what is the exact procedure to do so and what are the values of BID, CID, SID that have to be set?
